-  Tue Feb 16, 2010 5:00 pm
					 #319083
I was wondering when a material has 2 layers, and each Layer has only 1 BSDF. What is the difference if you set the weight for 1 Layer at 50 or set the BSDF weight inside that Layer at for instance 50.
If you do the Layer at 50 I understand this Layer will reduce 50% in its presence in relation to the other Layers. If there is only 1 Layer it will become half transparent. But if inside that Layer there is only 1 BSDF with a weight of 50% what happens ? Am I right to say that with 1 Layer and 1 BSDF component the weight of the BSDF component does not matter ?
Francois
Francois
