- Tue Feb 02, 2010 4:03 am
#318375
Hi, Can someone help me with enableing the parameters under Rende Properties in Object Properties panel. I work with SolidWorks 2009, and my Maxwell (1.7.1) plugin version is 1.8.3.0.
I am trying to follow the instruction in Maxwell Help file(page 8), where its suggested to open Object Properties tab in the Scene Manager and enable the 'Hide from camera' check box, but the five check boxes under Render Properties are not active to enable you to select anything.
I thank you in advance for your help
