By tischstuhl1
#317167
Hi all,
I have a problem with indirect lightning. The booth is illuminated with some HQI spots and an imaged based environment light. In the corner column (material: Vetro opalino) on the right side there is a hidden emitter.
Rendering with the hidden emitter muted result is fine,
http://www.flickr.com/photos/tischstuhl/4248119302/
when the emitter ist turned on I get these "fireworky" lightspots (diaphragm spots?) in the picture.
http://www.flickr.com/photos/tischstuhl ... otostream/
What have I done wrong?
Thanks for some hints
By zdeno
#317196
even fireflys are the most beautiful in maxwell from all rendering engines.
but seriously
if You used Vetro opalino with SSS (I found two in mxm think site) - this is not good to put emmiter behind SSS material.
By tischstuhl1
#317217
hi Mihai,
I tried rendering with another emitter, no change.
thanks zdeno,
your SSS-tip was right. now everything is fine!
By osuire
#317497
Any chance of improvement on emitters behind SSS materials ?
It would be great if I could light-up my tensile membranes from inside for night shots...
Olivier
By donb
#317573
I didn't know Maxwell did lightning. Cool! :P
