- Fri Jan 01, 2010 4:05 pm
#317058
I´m experimenting with emitters and SSS at the moment and I´m experiencing crashes when I put some geometry that contains an emitter material inside of a geometry with an SSS material. I´m using the latest Maxwell (2.0.1) and Maya Plugin (2.0.31) on a Mac Pro Nehalem 8 core, 6 GB RAM, running Snow Leopard 10.6.2. I´ve put a demo file for this phenomenon on my server. You can download the Maya 2010 file here:
http://www.marco-neumann.de/foren/emittersss.mb
It´s a simple cube with SSS material and a plane with an emitter material inside this cube.
It´s crashing when trying to render this. If you set the SSS coefficient to 0 (e.g. switch off SSS) the thingy renders fine. It´s also working when you place the plane out of the cube.
So what´s going on here?
Thanks,
Marco
Thanks,
Marco
Mac Pro Nehalem 8 core | Lion 10.7.4 | Cinema4d R13 Broadcast | Maya 2011 | ZBrush 4 | Mudbox 2011 | Maxwell 2.6 | modo 601 | 3DCoat
