By gadzooks
#315961
I canot seem to get these blades of grass to sit on top of the distribution obect see images
1. Image one shows a plane representing the ground plane, and another one representing a blade of grass. Once i created the blade of grass i moved the pivot point to the bottom.
2. Image two shows what is happening once the scatter modifier is applied to the distribution object. no matter what i try i cant get the blades to sit on the ground. They sit half way thru the plane what am i doing wrong??????
I want to make sure you know that Max's Scatter object doesn't treat the geometry as real instances. A better and more flexible way of creating randomly placed objects is with particles. Max's scatter object is old and clunky, and creates a single mesh.
Start with the Particle Source object.
By JTB
#315969
If particles are too complicated for you (they are for me sometimes) you can use "crowd"
By Polyxo
#315974
JTB wrote:If particles are too complicated for you (they are for me sometimes) you can use "crowd"
Its long ago that I used Max last time but I'm just curious - are Max-particles somehow transferred to Maxwell instances?
Thanks, Holger
Thanks, Holger
If you use the instance shape, yes they are.
