- Sun Nov 08, 2009 11:01 pm
#314306
Is the network render working for other users?
I am have real problems getting maxwell to render single images in the network. (Already wasted 9 hours on this problem and counting)
We are using 2 Mac Pros 10.6.1 with maxwell 2.01 (second release of 2.01) and the file is from Maxwell Studio.
1. After "Pack and go" I have to move or hide the original textures as it refers to these not the bitmaps in the "pack and go" folder.
2. When sending bitmaps to a render node it stalls after the 4th or 5th bitmap. (Some times it works with exactly the same files.)
3. If it does manage to start rendering neither the tif or mxi comes back to the network folder (it does have permission) so I have to copy the file from the temp folder but on some occasions there is no mxi file!
Below is the log from the window but I also get a message where maxwell is converting the name of the folder the images are being saved to the name of the local machine (render node).
[INFO] Benchmark of 32.860. Time: 17m39s. SL of 10.00
[INFO] Render finished successfully
[INFO] Ending Session...
QLocalSocket::waitForDisconnected() is not allowed in UnconnectedState
Render process finished successfully!
Start MXI transfer process
Connection for sending MXI file established
MXI sent to the manager succesfully!
Error in MXI sending socket. Code: The remote host closed the connection
- By Edward Leibnitz
