By Lynchon
#312342
Hola!
i,ve already checked older posts but couldnt find any with a direct answer.
I cant keyframe the sun´s time parameter, it has no animation tag unlike the other parameters such as ground rotation.
Is it a plug in limitation? because 3ds max and maya can do that.
Is there a way to fake this effect?
#312346
Coincidentally, this issue has not been noticed until last week by one of my testers. It is possible to make the date/time animatable by following these steps:
1. open Omxrendersettings.res (in [cinema folder]/plugins/Maxwellres/description) in notepad
2. find this:
Code: Select all
   DATETIME MX_ENV_DATETIME
      COMPACT_MODE;
      TIME_CONTROL;
      DATE_CONTROL;
      TIME_NOW;
      DATE_TODAY;
3. add in 'ANIM MIX' like this:
Code: Select all
      ANIM MIX;
      COMPACT_MODE;
      TIME_CONTROL;
      DATE_CONTROL;
      TIME_NOW;
      DATE_TODAY;
However, it looks like the Cinema date/time control used here does not interpolate between key frames, so it doesn't help much - you will have to key each individual frame. An alternative in the V2 plugin would be to use a light with a sun expression in the scene and animate that - the plugin will use it to locate the sun, rather than using the date/time specified in the Scene object. This feature will be added to the 1.x plugin in the next update.
By Lynchon
#312390
key each individual frame? buf, i rather prefer wait for the update.
So in V2 works as if it was done in 3ds max? instead of day light system a sun expression. Is that it? sure it is...
thanks again
