- Fri Oct 16, 2009 2:56 pm
#312080
*** I don't know if this should be in Max subforum... Using MAX Design 2010 and rendering from the plugin
My first silly animation with Maxwell... Actually it was a test...
I wanted to control a light's power and efficacy over time... So everything seems to work, except from the result...
Anyone has experienced this?
(Just a capture of the frames produced... This was the easiest method I found to show you as many as possible...
Also, I have a question....
Using Mental Ray, I know that I can make this using the mrSun (changing the spinner showing time) but this is obvious because it is an object (anyway something I can select on the screen)... With Maxwell, is it the same thing? Do I use the spinner of the Envir. Properties inside the Renderer dialog?
I thought I could use a daylight and choose this again as my environment but I want to know if I can do without it..
Thanks in advance for every answer
I won't sign it, if it is not a piece of art.. So far, I haven't done any...
Revit Architecture 2012, Max Design 2012, AutoCAD 2012, Moi3d, Maxwell, Octane ... and many working hours
