#311815
Hello everybody,
I installed the new Cinemaxwell plugin in order to check out maxwell v2 before ordering my upgrades. It works, but for some reason each time I try to add a maxwell material or edit one I get the error code "No preview folder was found in maxwell directory". If I edit a material I get the message once, if I add a material I get the message once for each maxwell material that is already in the scene.
I use Cinema R10. Did anybody encounter this before ?
Cheers
Jochen
#311835
Could you open Cinema's Console window (main menu > Window > Console) and let me know what is printed near the top? It sounds like Maxwell is not correctly configured on your machine, and that the plugin cannot find the Maxwell folder.
#311847
Thanks JD, you seem to be right. It says "Unable to find maxwell directory" ...
Okay, I think I know what the problem is. In order not to disturb something I installed the Cinemaxwell 2.0 but NOT Maxwell 2.0 which I installed on a different machine that does not have Cinema installed. I will install Maxwell 2.0 on my test machine and report back if anything changes.
Everything works fine now since Maxwell 2.0 is installed. Somehow I always thought that you would not need the actual Maxwell Installation to run the plugin. Thanks again for pointing me in the right direction
