By macray
#311774
Whenever I edit a mxm file with the MXED and then want to save it I have to navigate to the folder I want and the material has a very strange name.
The name is some kind of number/letter string and its located somewhere in a temporary folder.
When I start the MXM from Cinema (e.g. name.c4d in the folder /models):
- could MXED keep the folder of the Cinema file - So when I want to save it the folder /models is shown at first?
- and if I create a material in Cinema using the plugin and give it name - could MXED also keep the name as proposal that I gave the material?
It's a large waste of time to navigate to the correct folder and have to do it again for the next material.
#311834
You're correct, but it works that way because it has to: a material in Cinema must be written to an mxm file in order for you to edit it in mxed, and this involves using that oddly-named temporary mxm file. If you don't want edit a plugin material in-place with mxed, and instead wish to export it to an mxm file for later use, the way to do that is via the plugin's material editor: MXM Options > Export as MXM.
