By fuso
#311514
Hi everyone,
I know that this was posted numerous times before but even after searching I still couldn't find a decent explanation
or analysis of the infamous black dots in renderings. I have a V1.7.1 interior scene rendered with two settings, day
and night. The dots only appear in the night version obviously using emitters but no environment system at all. For
convenience and showing off to the client I've rendered the scene using multilight in cooperative and it just got
worse! That really is a shame because photoshopping all those dots out is a pain.
The scene itself is pretty tidy, emitting objects are reduced to the absolute minimum of faces (mostly single sided
rectangles, normals cheched), all materials/textures are spot on and the scene is not very big at all. Also, I checked
that all the bump values are within the recommended range and I sticked to the old 'rule' of not using white materials
over RGB 220 brightness. There is only two types of 'real glass' in the scene since I had to avoid AGS for many
reasons.
Furthermore, all the emitters are as close to the real wattage as possible(of course multiplied by the number of
emitting objects) and they do not touch any other objects which have glass or opaque materials attached to them.
So what could possibly the reason, what am I doing wrong here? Any help or advise is greatly appreciated!
Cheers,
Jost
#311519
Can you post a small sample image so I can see what the dots look like?
Generally, I have noticed that black dots can form when there is a material in the scene that uses SSS improperly (on a non-closed mesh, or intersecting). SSS is the first thing I would check.
By fuso
#311528
Thanks Bubbaloo for your quick reply, I was already worried no one would show an interest in those 'old stories'
anymore. There are no SSS materials in use in that scene. As for the project itself, it is confidential, so I guess it
wouldn't go down too well if I post it here. Any chance I can send samples to you in a different way, e.g. e-mail?
Can you pm me please? Thanks a lot in advance...
Jost
