By macray
#311037
Jeremy,
the render region is always overshadowed by the actual model. Is there any other way than to switch viewport display to wireframe to have it visible again?
#311038
This has to do with the order that Cinema asks things to be drawn; if you want the rendering region to be drawn on top of other things, you need to move it lower in the object list. Even then, an object being selected in the viewport may be drawn first.
By macray
#311053
thanks...
most of the times the scene object with the render region tag is the first in my object list.
