- Sun Oct 04, 2009 1:20 am
#310451
When mapping an image map in Studio that has 'black' in the image map, for some reason the shadow map does not render correctly. I have shown a few examples below.
1 - Base plane with diffuse mxm applied, no mapping and shadow output checked. It renders as expected.
2 - Base plane with brick texture applied, shadow output checked. It renders as expected (Identical to the first test above)
3 - Base plane mapped with black/white checker imagemap, shadow output checked. This does not render as expected, you can see the checker in the shadow?
- By jack marvia
