- Sun Sep 27, 2009 11:03 pm
#309330
I would like to share some work that was produced with the Maxon's Cinema 4D and Mograph Version 1 that has been rapid prototyped. It was produced through the mograph deformers and effectors to give it shape and variation in scale. A special thanks to Per for his help with understanding how to use Mograph creatively in a spatial sense!
Please note: The only renderings in this post appear at the bottom as sections. The black and white images are photographs of the rapid prototyping model.
It is called Field Notation.
This model began as a digitally based design expression that has been previously rendered in many incarnations. Finally, the design has been captured in time and phase in the physical world in a rapid prototyped format.
The process for fabrication - Selective Laser Sintering
The model material - Polyamide 12 (Nylon 12) Thermoplastic Polymer
Designer and Modeler: Tyrone Marshall
Software Modeling - Cinema 4D
Rendering - Maxwell Render
Fabricator: Shapeways Netherlands
Design Statement:
Field of Notation
A language of form in adaptation and performance in rhythm to express a mathematical sequence that acts through a continuous movement of light, shade, and shape to inscribe a spatial condition. In a motive design action of object mechanical motion, a digitally based form self-assembles into a cohesive moment from a sequence of animation and computation. The result is a structural signature of continuous movement whereby the sequence is captured in a moment of computational design expression. An expression that seeks to find economy in its suggestion of unitary construction formula which is an assembly of simple constituent parts that gather to form a larger contextual structure. The contextual form is a study in self-organization through the vehicle of computation and component geometry propagation through a three dimensional spatial construct of pure shape. In this construct of spatial signatures there is musical notation and progression of repetition, redundancy, hierarchy and modulation. There is an act of performance. The object is presented in its performance of a virtual simulation of a field. Born from shape, the structural form of simple geometry builds through a sequential path in digital self-assembly to inscribe a special place and suggestion of spatial inhabitation.
The nature of the parametric design produces a multi-variant state of many possibilities produced from sets of rules, limits, or constraints under the influence of time but forged in physical space under the criteria of design selection based upon a particular moment of consideration. One particular moment out of many wherein the differentiating factor is one of modulating frequency, variation, and amplitude of a control surface by design intent within the framework of time to pose a temporal and dynamic condition that in a moment describes the continuum of its many states that extend both before and after.
The work presented in this context is the begining of a certain continuum of constraints based on location, program, space, geometry, materials, fabrication, change, adaptation, and modulation of time, position, rate, scale, rotation, order, sequence, and shape signature in advancement of architectural design with investigations in emergent temporal and parametric performance.
The work is a study in the discovery of possible architectural spatial connotations in performance and emergent geometry. The resultant visual experiment is shown in simulation, sections, and its objective format. The work is a continuing sequence and thought towards an Architectural construct based on the language of repetition, geometry, redundancy, structure, shade, light, and shape.
Maxwell Render Sections
Design Statement:
Field of Notation
- By Matteo Villa
