#309296
Hello Julian,
Do you think about image layers on top of each other?
Yes, it is a limitation, the plug-in can't blend the image layers, and modo SDK doesn't give any help. But I am thinking about a solution.....
Márton
By Julian
#309314
Hi Marton - yes, I guess because maxwell creates materials in such a unique way and doesnt handle alphas like most renderers it will be a challenge.
The plugin is great when the materials are simple - I have had more success from modo than 3dsmax so far, quite impressive!
Opening into the studio makes more sense with complex materials so that you can work through them making corrections.
I know nothing about either SDK but is it not possible to get the modo plugin to recognise a material that uses an image and its alpha and force maxwell to create a second masked layer in that material?
Looking forward to your solution
Julian
