By macray
#309170
Thanks Jd, you did a real good job on the 2.0 intergration!
Up to now all works fine and with some help I even found the material override.
One question to Pack & Go: should'nt it pack the files in the end? Atm it's just collecting the model and textures in one place.
#309181
Hi Stefan, I'm sorry, but I didn't quite understand your question. How it is supposed to work is that during export, all referenced files are copied to a /textures folder under the mxs output folder, and all paths in the mxs are changed to be relative to the newly-copied files.
By zoppo
#310385
Do you mean "pack" like .zip? It has never done that.
By macray
#310411
zoppo wrote:Do you mean "pack" like .zip? It has never done that.
I thought so. but then I remembered something I translated from one of the manuals...
Thanks nethertheless the feature helps a lot exchanging models and rendering it on another pc.
By dynaraton
#312587
Just was playin with the new version..
Yes...great job JD. The converting materials tool works nice and saves much time.
This plug-in has come a long way for sure.
