- Fri Sep 25, 2009 7:27 pm
#308956
hello,
doesn`t matter what maya-version (2008-2010) i am using with the new plugin:
-the mx-material editor shown in the attribute editor on the right, does not show the layers (bsdf,layer,emitter,etc)
just the little icons are visible and working correctly, but no visual feedback above!
only after hitting several times the spacebar, you might be able to see and use these layers...if you are lucky!
-also after activating maxwell in the panels menu in the viewport for better shading quality,
all other views are refreshing no more! so you can pick objects, but you can`t see that it`s picked...also rotate, scale, etc.
only after hitting spacebar the view is refreshed...
anybody having the same problems?
is there any trick? what did i do wrong?
MacPro (octa) running XP64
nvidia GeForce 8800 GT
Maya 2010 64bit
Maxwell 2.0
thx
munch
Maya 2010 64bit
Maxwell 2.0
thx
munch
- By Edward Leibnitz
