By kreffell
#307040
Since my laptop's screen is not working, I am using the laptops hard drive through a portable usb mass storage device and connecting it to the different computers I use. Maxwell Studio works through the F:// drive, but when I want to use the rhino plugin version Maxwell fails to load.
Can you help me resolve this.
Thanks,
Keith
#307044
So, if I understand correctly, you have never actually installed Maxwell for Rhino on the machine you are trying to run it from? If so, that won't work; you need to install the plugin on the machine you are trying to run it from using the installer provided; it will not work if you just try to load the plugin from a random hard drive via File > Properties > Plug-ins > Install. This is because there is more to the plugin than just the Maxwell.Rhino.dll in the plugin folder; there are some other necessary files which the installer sets up on the target machine.
Let me know if I've misunderstood the situation.
Cheers,
JD
