By numerobis
#299257
i've installed maxwell x64 on winXP x64 and get the mxm preview in windows explorer.
now i installed maxwell 32 bit on another computer with winxp 32 and have no preview... is there any solution for this problem? can i fix it? :roll:
By m-Que
#299262
In Windows Explorer:
- find an .MXM file
- right click on it, choose 'Open with...'; you're now offered to choose a program - go to your Maxwell Directory, and chose MXED.exe - that's MXM Editor
-You should now be able to see the material preview
#299288
You can try this:
- open a command prompt (run as administrator)
- navigate to the Maxwell directory
- type regsvr32 thumbplug_mxm.dll
- hit enter
- you should get a dialog indicating that the DLL was registered successfully
Let me know if that takes care of it...
By numerobis
#299317
JDHill wrote:You can try this:
- hit enter
Worked!!! 8) Great! Thank You!!! :mrgreen:
Thank You too, m-Que!!! :D
