- Wed Apr 08, 2009 7:47 pm
#295519
I'm having real problems trying to align the mesh of a speaker grille. It seems no matter how I apply the texture (cubic, cylindrical, planar etc) I can't get it aligned properly......if it's correct in one part then it's stretched in another or else there is a seam. I've tried scaling in all planes, rotating, moving etc, etc.
Everthing is fine with relatively planar surfaces (as you would expect), it's when trying to apply to a more organic surface that the problems begin.
What I need is some kind of "wrap" function that maps the texture intelligently to the surface. Here are a couple of screen grabs that illustrate the problem and also the underlying surface that I'm working with. The part was imported as a STEP into Rhino and then exported using the Maxwell plugin. I'm trying to apply the map to a single surface (as opposed to several stitched or filleted surfaces).
Please help....it's driving me insane!
- By Mark Bell
- By Edward Leibnitz
