By trybul
#293793
I am trying to recreate this kettle,
http://www.hightechonline.ca/assets/pro ... f36576.jpg
as you can see in the pic, there is a light that lights up how much water is in the kettle. I cannot seem to make this work. I have modeled a piece of plastic, and a resevour for the water, put a light in the bottom where it exists in the kettle, but cannot get it to light up like this...
Any suggestions?
craig
Try using an SSS material instead with a pretty low scattering and absorption. You can start with one of the presets, for example the Polyurethane and change the hue of the colors.
By trybul
#293808
bubbaloo,
not sure i follow, how would you do it.. sorry. i am pretty new at this... I am finnally getting time to get back to 3d, and maxwell
craig
Create a texture for that area instead of modeling it, then convert it to mxi so that it will emit light.
It's really a shortcut. I always prefer modeling before texturing, but in this case it might look ok.
