#293763
In a scene with solidworks object, I can export as obj. As soon as I import an mxs from 'friend of modo' plugin, I loose the ability to export any object from the scene, even if I delete the modo generated objects.
This is quite simply a pain in the *ss. An imposed waste of time in an already hectic schedule.
My 2 cents..........
By mackshiva333
#293809
This is not good.
If you don't use a plugin and import geometry into studio, you are unable to export it to use elsewhere. Folks have suggested other ways in which this could work and still allow for protection. Maxwell and studio are awesome tools. It shouldn't have this kind of weirdness.
