By daros
#292565
about 90.000 crystals , 3000 K polygons.
The design is compleetly wrong. It's only a test for a project with a lot of chandeliers.
By m-Que
#292567
:shock: :shock: :shock:
How long did it take to render?
Did you try rendering it with dispersion turned on :lol:
By rusteberg
#292568
daros, what are your material settings for this crystal? (if you don't mind sharing). i recently had a project with chandeliers and had a difficult time getting "full" effect like you've shown here. .
By kami
#292569
I'd like to see the effect on the surroundings ;)
By sampson
#292571
wow!
By daros
#292572
Thanks m-Que! 10 minutes rendering time.
Hi rusteberg, yes in my first test i had the same problem because the emitters have been to small. the i increased the emitter size to the bulb size and it worked well.
anyway, thats's the material:
x kami, a interior scene is coming soon.
thanks sampson!
By daros
#292579
Thanks sandykoufax and devista!
A bit wired material setup and the chandelier is out of scale. Should be probably twice so big.
By daros
#292580
looks like a UFO.
Every building is so huge in Genova ?
It is a common theme in your work. Humans look like little ants in such titanic structures :)
By daros
#292587
I just sow that i did a mistake. The crystal material in this rendering is pure white lambert :)
x Bubbaloo: the version with dipersion is cooking!
x Thomas An: probably because most architetrure today is build for the media and not for the humans :) they have a pure iconic purpose.
By daros
#292599
wow! i'm not very familiar with dispersion but it looks like it will be difficult to clean up this scene.
Probably because rays are deviated to many times.
