#292388
the problem only happens in vista windows.
When I set up my scene and apply all the materials to the model and then I click render everything works fine, then If I suddenly stop or cancel the render, and I go back to change any material, and double click them to open them, they won't open.. is strange..
#292390
Which version are you using? There was a glitch similar to that in some older versions.
By locos77
#292437
I have vista ultimate and using the latest rhino plug in... it was not doing it before with the older plug in.
#292467
So this happens consistently, meaning, every single time? Otherwise, do you notice any other pattern?
By locos77
#292468
I also noticed that if I let it sit there for a while without touching anything will work again for like 5 mins. or more.
Also If it would not apply a material to surface only solids.. is weird..
#292469
Well, it doesn't sound like it's really a plugin-specific (i.e. code) problem. You could try updating/repairing the .NET Framework on your machine and checking that there aren't other applications running that might listen to/interfere with mouse messages.
About applying materials, do you mean using drag-drop, or using a command or context-menu command? There is a bug in Rhino that prevents the drag-drop from working when the plugin's heads-up-display is enabled.
By locos77
#292479
If I have a surface selected then select the material and right click to assign materials to the objets nothing will happen... the material would not apply...
#292485
Sounds like you've got multiple issues going on there. What happens if you:
1. make sure the plugin option 'Verbose Messages' is on
2. select a material
3. type the command: _Maxwell_ApplyCurrentMaterialToSelectedObjects
Is the material applied? Is anything printed to the command-line? Is there anything notable about the object, i.e. is it a block, part of a group, etc?
