By frosty_ramen
#291835
Is it possible to designate a specific number of cores to use on a computer using a node license, in a cooperative render? We have tried adding a switch in the properties of the ms program (e.g. -th:2).
thanks
dan
By frosty_ramen
#291858
Bubbaloo,
That worked! Much appreciated.
dan
By frosty_ramen
#291866
Just a follow-up question,
is it possible on a node, to specify the location where the temp file is saved at each "Next Update?"
dan
By zoppo
#292081
you mean like update_1 in folder \temp_1 and update_n in folder_n?
i don't think that's possible, as mw uses the os's temp folder.
otoh if i took your question the wrong way - there's your answer ...
set the os's temp path according to your needs.
By frosty_ramen
#292082
option 2:
will that mess up some things with windows?
By zoppo
#292086
no, not at all.
i have all my temp folders relocated on another drive, like e:\temp\.
they fragment a lot and this way it is easier to empty them from time to time.
my computer -> right click -> properties -> advanced -> env variables ->
upper field double click both and change as you wish AND lower field (system variables) -> TEMP and TMP change as upper field.
