By RonB
#291778
Did you know that an emitter set to a negative value will take away light from the scene to the same intensity as if it were set to a positive setting? Negative emitters in Maxwell work exactly as negative lights in other programs. It is a trick worth knowing and experimenting with. I don't believe it is mentioned in the manual.
I stumbled upon this sometime ago and was reminded about negative emitters by Lior Segal in an email. Thought I would bring it up here.
Cheers, Ron
By JorisMX
#291779
WOW!!!
Ron this is so Awsome! I was looking for something to make more dramatic lighting for a while now! :D
By JorisMX
#291780
I was eager to test this, but unfortunately this is not possible with the current Cinema4d Plugin :(
By tizxx
#291782
Sorry man I not understand you ...
It's also pollible to us with Multilight System ?
can you post a little sample image or scene ?
thank you.
By JorisMX
#291785
I tried it in Studio now and it is not working there either.
What I tried so far:
- Changing watts and/or intensity to negative values [values always jump to 0]
- Setting luminance values to negative values (lumen,candela,lux & nit) [values always jump to 0]
- Rendering with multilight and entering a negative value in the faders (this always results with a black (i.e. value of 0) emitter)
Ron, please let us know how you did this!
By RonB
#291787
BIG MISTAKE ON MY PART...I APOLOGIZE FOR THE MISPOST...I WAS WRONG ABOUT NEGATIVE EMITTERS...YOU CANNOT SET A NEGATIVE VALUE...
A ZERO WATT SETTING WILL WORK...
By JorisMX
#291788
We could post this in the Wish List section, however I believe NL won'T do something like this as it is not physicly correct...or is it?
Black Holes absorb light too! :twisted:
By johann.dugge
#291789
RonB wrote:an emitter set to a negative value will take away light from the scene to the same intensity as if it were set to a positive setting? Negative emitters in Maxwell work exactly as negative lights in other programs.
So in other programs that allow you to do this, if you have a GI lit scene and place such a negative emitter, the shadows it casts are brighter than the surrounding areas?
What's a typical scenario where one would want to use negative emitters? And what rendering packages do this?
Certainly an interesting concept.
By RonB
#291790
johann, Lightwave will do it. All one has to do is set a light to a negative value and it will take illumination from the scene. For instance, you can place a point light to darken areas that you might not want illuminated, say in a dramatically lit character study.
I did a scene sometime back and as I remeber...I was experimenting with negative emitters in it. I posted this thread before researching it further. I should not have done that...again, my mistake...sorry.
By RonB
#291791
O.K. and this works: An emitter with a zero watts setting will pull illumination from the scene. My mistake that I thought I remembered it possible to dial in a negative value...you cannot...but a zero watt emitter will darken the scene.
Here is the original post from 2006:
http://www.maxwellrender.com/forum/view ... light=mime
Here is an example:
Same lighting in each, the Sky Dome. You can see the edge of the emitter between the objects in the right image and the effect. Normally I would use Tom's method for hiding the emitter from the camera view.
[/img]
Can you replace the emitter with a black lambertian (RGB 0) ?
It would probably have the same effect.
By RonB
#291793
Could you make the black lambertian object invisible to the camera and retain the effect?
"invisible to cam" in object panel won't do..?
By RonB
#291865
Tom, Boy that article sucks! :lol:
O.K., so the plane is just blocking light?....Geez, now I feel like a real nit wit!
Sort of like I yelled, "Eureka!" and my pants fell down.... Image
