By def4d
#291592
I have textures already done (diffuse, bump...) and i'd like to make them bigger, make them tileable etc
Is there a way to apply all photoshop actions to all layers at the same time?
or
Should i save all the actions made on the diffuse map for example, and apply them on the other maps?
Does Maxwell handle .psd files containing all the channel maps?
thanks
I can answer your second question. No. No psd files... :cry: I've read it on the wish list many times.
In PS, can you select all layers, then apply the action? Just guessing.
haaaaa, I see what you mean Def4... hehe.. all channels made.. but no seamless... make one seamless by hand... huuuuuhhh.. how do you do the other ones the same.. notably if you used the mouse with the stamp tool... huuuhh... no PS actions will mov your mouse... huuuu.. so how..??
hehe.. zorro est arrivé.... !
I found one way.. a bit tricky, but it worked wonderfully...
here is the answer you're looking for..
http://www.macro-expert.com/
It works really really good.. as expected that is...
((and there is a demo) (it's fune to see you mouse doing back the job you just did... and you can even choose the speed... hehe)
hope this helps..
:wink:
well the macro expert will do the job... :wink:
By def4d
#291667
Thanks again Hervé, and nice to see you again :D
he he... I was very busy with some fruits renders for some fruit juice labels... :) ... but I'm never far away... :wink:
By def4d
#291670
:shock: Amazing works on your www :shock:
