By greenlollipop
#291444
hello -
i have this question posed in a couple of other forums and this forum may not be the exact place, but i figured i'd fish here as well. here is the problem:
i have a .dwg file of a chair that i need to use in a rhino model. the problem is that when i import the .dwg into rhino, i have no control over the mesh. when i render the model with maxwell, the mesh on the imported chair is not fine enough and it appears fairly voxelated (?) in the final. any ideas on how to solve this issue?
thanks,
jc
#291445
All you can do, besides re-modeling, is to adjust the vertex normals: try using the Weld command.
Cheers...
