By Josephus Holt
#291113
I've used AGS glass (accessed via the wizard) in C4D, but can not find in the Rhino plugin. Any help would be appreciated.
#291120
AGS is one material that is not yet implemented in the Rhino plugin's material wizard. Two options are to use Maxwell MXED to create an AGS mxm and import that into the Rhino plugin, or just to import one of the AGS materials in the standard materials library (located in the ateam's special folder under [drive]:\Next Limit\Maxwell\materials database\mxm files).
By Josephus Holt
#291130
Sure...I can use the Maxwell Material Editor... :oops: I get so used to using the plugins I forget that is even there. Thanks, that works just fine..as well as the link to the A-Team materials...did not see that file when searching for AGS glass...was looking for "AGS" :shock:
