- Tue Feb 03, 2009 5:35 pm
#290786
Hi ,
working with blocks in rhino and all is good.
When I open the mxs in maxwell none of the block appear in the render window but then do render.. Is this correct? If I select the original/parent then I can see the blocks as bounding boxes but I cannot select one and then use the auto focus command..
Should I do all the auto focus in Rhino?
Thanks
Rich
Thanks
Rich
- By Mark Bell
- By Edward Leibnitz
