#290544
Hej hej!
I've been using an English version of Excel for as long as I can think, but from time to time I have to use the German version at a relative's. This means I cannot use IF() in a formula but have to translate to WENN() - it's a major pain, and unfortunately installing the english language pack is no option, and I don't want to use a dictionary.
There must be a way to force Excel to interpret a given formula as if it was English. In VBA in Rhino I think you can use _if, but I have had no such luck in Excel formulas. And browsing the net has yielded anything useful either.
Anybody have an idea?
Thanks!
By jvanmetre
#290545
Can't you do a global search replace?
Go to Edit => Replace
jvm
By johann.dugge
#290567
Thanks jvm, but that would require that I take note of all the expressions (IF, SUM etc) I use and then still translate them for the search replace. And my formula would not get evaluated until I translate it. In addition
Code: Select all
IF(condition, iftrue, iffalse)
translates to
Code: Select all
WENN(condition; iftrue; iffalse)
(note ; instead of ,)
i.e. the search replace would need to be a lot more elaborate.
By jvanmetre
#290569
I'm not following...what exactly needs to be translated..whole statements or key words in the formula?
By johann.dugge
#290570
Sorry I wasn't clear enough about my objective, let me try to rephrase:
I run Excel 2007 German, no English language pack is installed
In the German version, a valid formula in a cell would be:
Code: Select all
=WENN(SUMME(A1:A3)>=0; "positive!"; "negative!")
But, being used to the English expressions, I am too lazy to learn all those translations (they are not very intuitive, to me anyways). When I use the English formula, German Excel will produce an error message because it does not recognise the English keywords:
Code: Select all
IF(SUM(A1:A3)>=0, "positive!", "negative!")
So I would like to instruct my German version of Excel to interpret the formulas (or parts thereof) as English, for example indicated by a prefix "_":
Code: Select all
_IF(_SUM(A1:A3)>=0, "positive!", "negative!")
Furthermore, mixing of English and German would / should be possible:
Code: Select all
=_IF(SUMME(A1:A3)>=0, "positive!", "negative!")
So I may be asking for something that Excel cannot do, but I hope there is a way. Or maybe there is a global switch that doesn't require the English language pack be installed, but translates keywords and functions correctly. When you import a spreadsheet that was created with the English version using the German one, Excel will translate and display the German equivalent functions.
Does this make more sense?
