By tanguy
#290238
When we use merging technic to achieve a higher SL, is there any possibility to save the channel of the merge ?
Because when you got a Sl.21 on a final merge, the ObjID, Alpha, etc are still to the node SL level...
Somebody know a tip or it s not possible ?
Tanguy
By polynurb
#290247
no it is not possible to render these channels in coop mode,
but they don't need as much cpu power/time like the render channel, so if you cue up these jobs on one seperate (even weaker) machine while the actual image is processed cooperatively on the others, you should get good quality once everything completes.
By tanguy
#291553
Thanks for the reply, and now i just rendering parallel rendering and one of them compute also a ID and alpha pass while the other not.
