By abaez
#289839
Is there a way to set up the percantage of visible transmittance of glass
to run different renders comparing different types of glass
Thanx in advance
AB
By JorisMX
#289870
Not really sure what youre getting at.
But if you visually want to check how your glass material is behaving in terms of attenuation and roughness I suggest using a special Preview scene like the Attenuation Scene which I think can be found here somewhere on the forum.
It's also in the maxwell manual in the SSS Material Chapter.
By abaez
#289934
I am trying to run two different renders which will show the difference in glass properties
a real life comparison for a daylighting analysis/ design
with two different types of glass(real life conditions)
one of which has a visual transmittance level of .63
the other has a visual transmittance level of .43
