By deflix
#287201
When we lose a coop render due to a 'lost' node we collect the MXI's and merge them. My question is this; each node has two mxi files: (normal and aux) I understand that you need 3 files to create a merge, so therefore if I had 3 nodes on the coop would I only need one file from each to create a sucessful merge?
Thanks.
By QuakeMarine1
#287202
you need at least 2 files minimum and yes one of each node is enough (i wonder why you have 2 mxi written)
