#286770
hi @all,
might be a dumb question:
i have an older scene i needed to re-render yesterday. in this scene is an
object that has 2 selections and 3 materials.
2 for the selections and one for the rest.
those 3 materials are cubic mapped with various values in "tiling"
and (don't know the correct term right now) "x cm * x cm * x cm".
with the old plugin this rendered flawless, with the 1.8 the material most to the right determined the tiling for all 3 materials, so in the end i had to split up the object.
did i do something wrong?
z.
By MS
#286776
I have had same experience...
Maybe (if I find it...) I can provide the scene to JDHill if necessary.
#286797
No example necessary, 1.8 only supports 1 set of UVs per object. This limitation will be removed in the next version.
