Thats correct.
Something that I've experienced is that if I use the same machine as File-server for MXM files and MXS file + manager + server I sometimes get some instability problems...
Also if you are using winXP64 or winXp32 as fileserver, you will have a problem when you are passing 10 rendernodes... You will need a server OS on the fileserver.
Right now we have a Novell server only running as a fileserver (MXM, MXS files, MXI output) one machine is running only manager, and the rest are running as servers. All of the machines has winXp64 and 4 GB of ram, except the fileserver.
works like a charm
