By reiter
#27843
:shock: ...what is that?? head is solid without holes....
...don't think it's plug in error... rhino/rhinoll/maxwell
reiter
By michaelplogue
#27855
Hmm.... What material shader are you using? Is there a UVW map on the object? Are you using a bump map? If you are using any images for texture or bump, what format?
Two things come immediately to mind. either you are using a non-RGB image for mapping or bumps, or your using something other than JPG's.
By reiter
#28112
michaelplogue,
no map, no textures - just one object modelled with control points out of a sphere (object works fine in flamingo). the color applied is indifferent as i tested with several and received allways the same results...
kabe,
looks similar - could be the same problem, even if i didn't meet your results when trying with configuration of cubes with rounded edges. what exactly do you mean by this:
The Cinemaxwell plugin does not convert polygons correctly, that are facing a certain direction in their object space.
This happens to *all* objects with polygons facing -Z, excepts if they are facing -Z exactly.
reiter
