By deflix
#284405
When network rednering in coop mode, at the end of the render is it normal that when sending and recieving MXi files between nodes during final compilation is it normal that the network utilization swings between 80% and 0.2% or might this more likely be to do with my netwrok setup? It takes ages for final compilation as a result.
Thanks in advance.
Can you give more information about it? How many nodes are there? What's the scene resolution and MXI size? Do the nodes have enough RAM and disk space each?
By deflix
#284720
nodes are 8core 8gigram - mxi is small in this instance about 800mb.
probably a network issue isnt it? or are there known issues with transfer rates?
