- Wed Oct 08, 2008 7:01 pm
#282058
Still with version 1.7.1, network rendering is broken on Mac OS X - I've had Ignatio from Next Limit try and get a render working on my machines and he's had no luck so until the software is fixed, I have found a simple workaround:
Use mxstudio and select Render Region, then cut your rendering into two halves on each machine with a slight overlap to join them in Photoshop later. It's not perfect but it works. Be careful with your marquee selection not to select outside of the cameras bounds since it will render the whole scene and not the part if you do.
- By Edward Leibnitz
