#281829
Yes, that's correct. Well, last time I checked (for Rhino). You can always consult the plugin's the log viewer about this - roughly sixty seconds after startup, you should see printed there whether or not you're running an outdated plugin.
By NoahPhense
#281830
JDHill wrote:Yes, that's correct. Well, last time I checked (for Rhino). You can always consult the plugin's the log viewer about this - roughly sixty seconds after startup, you should see printed there whether or not you're running an outdated plugin.
Gotcha, thanks. You're talking about the regular log window right?
- np
#281838
I mean the plugin's log viewier, i.e. main menu > Maxwell > Plugin Windows > Log Viewer.
By NoahPhense
#281840
JDHill wrote:I mean the plugin's log viewier, i.e. main menu > Maxwell > Plugin Windows > Log Viewer.
Ah, thanks JD.
- np
