#281691
I've been working with this for the last few days http://www.nliteos.com/
Once loaded you go through a series of screens where you choose what features you want in the "final build" of the operating system. It's set up such that if you don't understand *everything* it gives you a bit of information about each entity. If you undestand the operating system then its a breeze. It took about 45 minutes the first time I used it to get an image of the OS I wanted. It could have taken less time but I went through every detail. Once I was done I had an OS image that was 100 Meg - a far cry from the typical system install. If you don't need access to the internet you can strip out IE. It does far more than simply take out "themes" or what have you. Many of the options if not understood could make a mess of things.
I installed this on an older machine and really couldn't believe what I am seeing. Its not the prettiest thing you've ever seen (I took out anything that was more than a basic button with text). I don't know the last time I clicked on an icon to open something and it just "opened". *POP*
I've been going through building a smaller and smaller OS for a project I'm working on that will use a VIA pico-ITX MB. I looked at using WinCE and the embedded version of XP. For me it makes far more sense to buy an OEM version of XP and strip out all the crap than get into CE or such. On that note; this IS NOT a pirate OS or anything like that. You must have a legitmate OS version with the serial number.
If it wasn't such a PITA to unregister and re-register Solidworks I'd do this to my main machine. If you have an older system that you want to put XP on give it a go. AS with any new install you don't have to activate for 30 days - plenty of time to try it out.
By pluMmet
#281696
This is too too cool!
And it works on xp64 too :D
I'll do a format c: soon, i'll consider it :)
By mtripoli
#281776
Over the weekend I prepared another version where I was ruthless in stripping things away. This included IE and all the "old" drivers that get loaded by default (other than things like "VGA" support to get running). This time around I also included SP3 (WinXP). I remembered to add a directory with all the system drivers specific to the target MB. I stripped out DHCP and put in static IP and such. I also made this a "stand-alone" install with all the information asked at the beginning of a standard install (name, network name, serial number etc. - this is all done inside nLite). The final image was 107 Meg. This is 576 Meg smaller than the normal install.
Once it was installed (which from delete partition, "quick format" to running) took about 10 minutes. I installed the system drivers and installed Opera. It screams... I have to admit; I'm going to breakdown and install a theme (I like the "black" Zune one from Microsoft) just because it is *really ugly* without a theme. On my "embedded" target I'll leave it off...
I always though IE is so deeply tied into the OS that removing it cripples various functions.
I made myself a nice XP64-SP2 CD as well, what a great, user friendly program. I included the latest nvidia gfx driver, lan and wlan drivers, and still ended up with ~450MB. No idea if that'll work out in the end :)
Thanks again for the pointer.
By polynurb
#293564
if you need to install custom drivers during windows setup and don't have a floppy drive, this is the tool to go for!
i just reinstalled x64 with sata i AHCI mode to use hotswap features .. it was very straight forward to create that "slipstream" disk an i did also put all other drivers on it (lan,chipset,marvell raid, audio..).. worked great!
By Leonardo
#294539
what exactly does it do? I just finish installing a new copy of windows xp (did all the updates to sp3, installed all the drivers, all the programs that I use).
Can I make a disc image, so next time It's 1 click process? :D
By numerobis
#294578
nlite lets you set up a preconfigured or ripped install cd/dvd for windows. you can add/remove drivers, service packs or programs or build an unattended installation.
To make an image from your fresh and clean installation you need an image program like Acronis TrueImage. then you can boot from a recovery cd and restore your clean install within minutes...
(trueimage saved my a** many times! :wink: )
By Micha
#294584
Is the time for booting the system faster per nLite?
By numerobis
#294586
i think you can make it faster. it depends how much parts/services you disable. even without nlite you can disable several services in windows and speedup the booting.
in other forums there are discussed optimized versions for gaming with a minimal config - these should load very fast.
By Leonardo
#294594
numerobis wrote:nlite lets you set up a preconfigured or ripped install cd/dvd for windows. you can add/remove drivers, service packs or programs or build an unattended installation.
I was playing with nlite yesterday... I made a Windows xp cd with sp-3, automated, with preloaded drivers. and I took few things off :wink:
I wrote on the CD: "Untested" I'm not about to do the whole process again to see if it works
