By robin of nottingham
#281270
done a 360 thing in rhino and rendered it with maxwell automatically in series of frames as an experiment. Now I ve got these frames now numbered of course..... I guess I need software to put the frames into to make the animation?
Can anyone suggest good software for this? I mean something fairly cheap as I ll only be doing animations every now and again. Id like the animations to used on websites n all that. I ve flirted with flash on a mac a long time ago but now I am pc only.
any advice?
thanks,
r
By jvanmetre
#281297
Just recently completed animation myself...an inexpensive option is quicktime pro.
jvm
By NoahPhense
#281315
Wow, didn't know Blender could handle video sequencing.
- np
#281369
I ll check out blender for that and quicktime pro. Got a new problem :
Just made a 360 degree revolving animation in rhino then got to render the sequence in maxwell.All was going well and done the 322 frames out of 350 total. Came back to my machine after some 5 hours rendering and it said runtime error maxwell closing. All the renders are of course saved as png but its now stopped. All the mxs files are saved and numbered so I thought I d just render them one by one but when they are opened and rendered the lighting is different I suppose because its maxwell and not rhino? I ve not altered the lighting in any way so I am not sure whats going on?
why was runtime switching in and what is it?
Is there a way out of this? Fed up now as I thought Id had it nailed.
help......................
#281373
You can re-start the animation render in MXCL:
- Start > All Programs > Next Limit > Maxwell > Maxwell Render
- File > Open, open one of the MXS files (shouldn't matter which one)
- in the Render Options tab, type 322-350 into the Animation > Frames box
- start rendering
As far as your lighting being different, I don't know any reason for this to happen - had you been adjusting the fStop/Shutter or changing Multilight values in MXCL while the animation was rendering before? MXCL doesn't know whether it was started by you or by the plugin, so there's no reason for a difference there.
#281402
cant find that... I opened a file/frame and then the render options tab. Headings are general..output..simulens..render channels..illumination layers..caustic layers..viewpoint preview, Am i lokking in the correct place?
is it the : output. command line options
thanks,
r
#281408
It's at the bottom-left of the Render Options tab:
#281421
had studio open. Did nt know that you could open maxwell render without studio or rhino. I think then that the renderings will now be the same then!
This is a real big help thanks guys,
oh and its working and saving xxxxxxxxxxx
r
#281453
ah all is now well and I ve got an animation! Is it possible to load it on this forum page? if so how? Big thanks to all thats helped so far. That blender does look interesting for other stuff also.
thanks,
r
By bjorn.syse
#281507
Try Youtube, and embed it or link to it from here. I'd love to see it.
Which software did you use to put the fram together in the end?
- Björn
#281511
think it will take some time to appear on u tube so I ll see it it loads then link it to here. Blender was the software that I put it together with in the end. I tell you what theres no way of working it out by yourself without that lesson from tom! Theres menus that are hidden that you d never even find! So step by step I followed it. I am not sure yet about the export option that I used... its come out as a AVI clip.
maybe its compatable with u tube maybe not.. there are so many export options that i ll have to just try a few.
Its only a simple animation thing for a specific job but its been very useful and enjoyable to do.
I ll update when and if it loads.... blenders real good I would recommend it and its free!
