By Fille
#281233
Hi JD! Thanks for the new plug-in - again :)
Here's something that I haven't remembered to report earlier... It seems that using worksessions (which I do a lot) add the materials from the referenced file(s) in the current file - permanently. This only happens if you save the file during a 'worksession' (and of course you do). If you have many referenced files attached you get a lot of materials in the file that don't belong there the next time you open the file - even if you don't attach anything this time. I don't think this is desired behavior... or?
Thanks!
Philip
#281238
Thanks Philip - it's scenarios like this that I created the Database Manager system to address. Previously, the materials would have to be added to the document, but now they really don't have to be - so thanks for the heads-up. I just hadn't happened to think of the worksessions angle until you posted - look for different behavior in the next version.
Cheers,
JD
By Fille
#281239
Ok, thanks JD! :)
Philip
