By Bogdan Coroi
#280736
Could you describe a bit what's not correctly working?
When having the option set, the plug-in should export all frames in the directory specified in the MXS Output editbox and start rendering in MXCL sequence mode (frame range is rendered with one instance of MXCL).
By sandykoufax
#280752
MXCL doesn't start.
I don't know it's only my problem. but I just made a teapot only and tried to render.
MXCL viewer is disappeared right after start.
