By purCAB
#279768
I am attempting to utilize an image based environment but I am not able to "see" the environment in either SolidWorks or in Studio (using export to Studio) -- I have checked Screen Mapping on.
Here is what I have done. Using Maxwell Render, I loaded a .jpg image and then saved is as an mxi. In SW, I opened the Scene Manager and set the Environment Type to Image Based. Under Image Based, I set the path for the mxi file, Link Channels-Yes, Enabled-Yes, Screen Mapping-Yes. Checking Illumination, Reflection, and Refraction all indicate enabled (as they are "linked"). I then close the Scene Manager. There is no indication of the image in SW, but I'm not sure if it's expected to appear here. Finally, I export this to Studio.
In Studio, my assembly is fine and the environment settings are correct, but I can't see the background. Using Textured, shows my materials but no background, I have also tried toggling the Screen Mapping off and then on, but again nothing. I suspect that there is something that I have neglected to enable, but I don't see what.
Any help or insight would be most appreciated.
Saludos,
Ken
#279770
Hi Ken,
The plugin cannot display HDRIs in the SW viewport, so you are not missing anything there. Once in Studio, try activating (i.e. clicking on) a viewport and then pressing 'k' - this key is the toggle for turning the background display on/off.
JD
By purCAB
#279776
JD --
Thanks for the very quick reply. Yes, that seems to help a great deal!
Are there any plans to add the background visibility (and therefore the ability to set the entire scene) within SolidWorks?
Ken
#279779
I have plans for everything, but I've not yet prototyped anything in this area.
By John Layne
#279847
JDHill wrote:I have plans for everything, but I've not yet prototyped anything in this area.
Does this include world domination?
I am using it right now on M1 Max and latest macOS[…]
