By johndoit
#279270
Hy to all
i´m new here and i make my first steps with maxwell,
i want to make a litle night rendering, with indoor lights
what are your way´s to become a good result;
how should i set the ligts in FormZ and in maxwell?
how should i set multilight ?
Thx for Tips
johndoit
By pelias
#279279
You have 2 options:
1. use formZ lights
- point and custom lights are converted to Maxwell lights if "Export formZ lights" option is checked in Lights tab of Maxwell options
- you need to control the light intensity - typically you will do this in Maxwell Studio.
2. use Maxwell emitter material
- create geometry for lights
- create light emitting Maxwell surface style - map formZ style and create emitting material in MXED
- Note that there are presets for different lamps in MXED - this will give you correct lighting as long as you model in correct units.
- assign surface style to light object
Hope this helps.
By johndoit
#279282
:roll:
thank´s a lot, this was exactly what i want to know
