#277818
Hi, Im getting this when i change to "Render" mode in the viewport.
The render still comes out fine but as you can imagine its impossible to identify or adjust the texture mapping. I just uninstalled Rhino, Maxwell for Rhino plugin and completely deleted and uninstalled everysingle plugin just to reinstall it have the same problem. Dont know what to do.
Everything things is golden with a map of a living room in it or something.. Any help will be greatly appreciated. Thanks.
#277860
Your graphics card is having some trouble with Rhino's environment mapping -you can try adjusting your video card's settings, Rhino's OpenGL settings, or if you can't fix it that way, go to Scene Manager > Plugin Options and set 'Disable Material Environment' to 'Yes'.
Cheers,
JD
By sfawehinmi
#277861
It apparently only occurs when i apply mxm materials not default rhino materials.. and doesnt seem to be affected when using emitters either.
Someone... anyone, any ideas? pls
By sfawehinmi
#277862
K.. ill try one of those options.. Thanks.
By sfawehinmi
#277865
Dont know how to tweek the first two options but i disable the material environment and that worked. That will have to suffice for now.. at least until i want to use Material Environment.. If that ever happens anyway..
Thanks a bunch man.
:D
#278385
In the next update, 'Disable Material Environment' will be on by default.
