#276924
Hello,
When trying to update maxwell's material preview inside material editor nothing happens. If i import a maxwell material i can see the preview but when i change any parameter preview does not change. Any thoughs?
Thanks,
jose espizua
By Bogdan Coroi
#276933
Make sure you have the 3dsmax renderer set to MaxwellRender.
By jespi
#276934
Do you mean in F10 common SetUp->asign renderer->maxwellrender? Yes , i have maxwell render as my default renderer.
Thanks
By Bogdan Coroi
#276935
Yes, I was talking about F10.
MXCL starts when trying to render a scene?
By jespi
#276937
yes,i can render. Also no problem with sky preview.
By Bogdan Coroi
#276996
If you press the MXED button from the Embedded MaxwellMaterial, does it open MXED?
By jespi
#276997
Thanks for the replys. I've decided to reinstall operative system because i was experimenting a few more issues. In a few hours I let you know if i can solve the problem.
Thanks a lot,
josé
By jespi
#277013
Well, still does not work after reinstall windows and 3dsmax...
To Bogdam: Yes, if i press mxm button MXED is opened and i can make the preview within MXED.
To Bubba: I have checked the route and changed the preview scene to Tom's stage 1 and same problem.
By Bogdan Coroi
#277016
The only possible problem I see here is that you don't have write permissions in the directory where the scene preview is.
When trying to make the preview, the plug-in reads the preview scene and creates a temporary file in the same directory. Here, if it can't create the file, when pressing the Preview button you'll only see the mouse cursor changing to HourGlass and back to Array, but no preview. Since the plug-in is embedded in 3dsmax, you have to make sure it has write access in the directory where the preview scene is. From your signature I see that you're running Vista. AFAIK, you can't write in \Program Files\ unless you have Administrator rights. Make sure you run 3dsmax as Administrator (Right click on the icon->Run as Administrator AFAIK).
By Fernando Tella
#277018
Maybe you have assigned Maxwell Render as render engine for production but not for material editor; usually the option is linked but you could have changed that.
By jespi
#277019
:shock: O.K Bogdan running 3ds max as an administrator made the job. I'm new to vista but this permission issue is annoying me, why if my account has administrator privilegies must i run the software as an administrator.
Thanks so much for your support.
By Bogdan Coroi
#277028
AFAIK, this is because you have UAC (User Account Control) enabled. In this way, an "admin" account will use 2 access tokens: the administrative token for administrative tasks and the standard user token for the other tasks. You can disable UAC if you know you won't need it.
Highly recommended to avoid other issues like this in the future. That's one of the first things I did after I installed Vista.
