By Teccboxx
#276892
Been searching the forums and havn't found the answer to my question. I am trying to render a pretty basic assembly, however when I go to export I turn my image quality up in solidworks just below the red and when I open it up in MXST it is missing some of the parts. Plus the MXST viewport flashes like a strobe light.
I guess my question is, is there a file size limit or amount of data that the Solidworks plugin can export???
#276895
Hi Teccboxx,
No, there isn't any size-limit enforced. Regarging the 'when I open it up in MXST it is missing some of the parts' issue - are they just missing in MXST, or also when you render in MXCL directly from the plugin? Do you have the 'Export Duplicate Bodies as Instances' option enabled? How about the 'Export Absolute Coords' option? I would need to know these things first, to determine if this is looking like a plugin issue or an MXST one.
Thanks,
JD
