- Sun Jul 13, 2008 8:51 am
#275616
Here's a little screenshot of my DBM (Database Manager) for reference.
It seems that the Volume View icon button at the bottom and the Volume View menu item in the popup menu is not in sync. Using the above image as a reference...
1. Click once on "Plastics". Now click the Volume View icon at the bottom. The DBM says "There is currently no Volume selected."
2. Now click the Materials icon at the bottom to go back to the catalog.
3. This time right click on "Plastics" and select "Volume View" from the popup menu. This time the DBM correctly displays the materials within Plastics.
I guess it depends what was the intent with this. To me, when I click once on "Plastics" it hilites. So obviously it IS selected, therefore I'm thinking it should display the contents of Plastics, when I click the Volume View icon at the bottom, as opposed to saying that no volume is selected.
Of course if I already selected the Plastics correctly, then I hilite (eg click once) "Colors" on the catalog view then press the Volume View icon at the bottom, the DBM will display the previously selected "Plastics", since the only way it will give me the correct volume view if I select the "Volume View" menu item from the popup menu.
I guess it's just a little confusing, because when I think of TreeView controls in general, once I click on the parent node, it is considered selected. But in this case it is not, until I confirm my selection from a popup menu.
=LES=
- By Edward Leibnitz
